SQL Cluster behavior
  • Feb 14, 2024 4:36 PM UTC
  • 89 views
Hello All,
I have a question regarding the behavior of an SQL cluster.
Scenario:
This cluster is made up of 2 VMs with shared disks. There is also a witness client to this cluster. The witness client was rebooted unexpectedly, and so I’m assuming Commvault determined that the cluster was lost, since a backup set and instance were automatically created on one of the client nodes. What brought our attention to this was that we received an alert that this subclient could not be backed up since there was no Storage Policy associated, and permission not configured, which was to be expected.
My questions:
  • Is this normal behavior? (I believe that it is?). If so, why would Commvault do this given it can’t be backed up anyway with no storage policy associated, etc...?
  • Is there an option to disable this behavior?
  • Am I correct in saying that by the witness client being rebooted, the system assumed the cluster was lost? Also, this is not the same as a failover, yes?
  • If an actual failover occurs, would Commvault be able to continue backing up the SQL DB without intervention?
Thanks for any help or relevant docs on this topic
Cheers!
Best answer by ddwyer
Hi Lani,
I believe this is a duplicate of:
If anyone is watching and wants to see the answers provided on that other thread
David
  • Feb 14, 2024 11:06 PM UTC
Hi Lani,
David
