Staging DB recovery
downhill
Explorer
Can someone confirm whether when staging the DB the Command Center isn’t usable by design? The Console works but I can’t seem to get the web UI to load (Please wait while our servers start up. This may take a few minutes.). curl returns the fact it’s running. I replaced the signed certs and all that but it seems it just doesn’t function so I’m wondering if that is expected behavior.
thanks
Best answer by Gergely (Sydney)
Ah, my bad, I just assumed it’s Windows. ‘commvault list’ should list CV processes and if they are running. When we are staging (to check config, etc.) we use the ‘Staging’ recovery option.
https://documentation.commvault.com/11.46/commcell-console/command_line_parameters_for_commserve_recovery_assistant_tool.html
https://documentation.commvault.com/11.46/commcell-console/commands_to_control_services_on_unix_clients.html
Gergely (Sydney)
Should work (we do this all the time), try running ‘iisreset’ after staging and confirming all CV services are running
downhill
Explorer
  • July 29, 2026
Hmm, that’s what I thought but haven’t done one recently.
This is Linux. I can see spewing errors on the CommandCenter and WebServer logs about  RequestAuthUtil:addMachineAuthToken:140 - Machine auth token is null or empty for url:newserver.
I’ve tried recovering this DB a few times now, trying disabling MFA, etc, but can’t see what’s failing. From the Console PoV things look fine.
Services look good according to systemctl. I don’t see a pid for cvd though (should there be if I recovered using all the “disable” options?
thanks
Gergely (Sydney)
downhill
Explorer
  • July 30, 2026
Another “I can’t explain it”. Ran the recovery again without the other options and this time the Command Center is accessible. The inconsistency is frustrating sometimes.
thanks
