Storage Accelerator and Data Domain
Hello All;
I found this topis:
An I have similar problem in with Data Domain, in the logs I found taht StorageAcceleratorAutoDisabledUntil
and i have a question:
Where I can found exactly this keys on Linux and Windows systems?
MediaAgent/StorageAcceleratorAutoDisabledUntil
MediaAgent/StorageAcceleratorConsecutiveFailureCount
I have installed on clients Media Agent and client can communicate with DD.
Best answer by Ponte_Vedra
Hello Pawel,
I was able to locate the key to disable storage accelerator - it can be found by navigating to media agent properties → Additional Settings tab → Click Add → Lookup → In the Find text box type storage and it will appear at the top titled DisableStorageAccelerator
Here is a screenshot for reference. Note: Use this same process for Windows or Linux media agents.
I was not able to locae the ConsecutiveFailureCount key - you can try reviewing selections found when using Lookup. It could be a key that requires a support engagement to collect needed details - may be worth checking out if you have no luck hunting it down.
RubeckDK
Explorer
  • January 23, 2025
Hi…
On Linux, the entry is found in the following file:
/etc/CommVaultRegistry/Galaxy/Instance001/MediaAgent/.properties
On Windows, it is in this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\MediaAgent
/RubeckDK
Hello Pawel,
  • July 24, 2026
Hi…
/RubeckDK
Thanks Dude for help becasue I stuck on this strange blocks …. Best Regards for Master “KimVault” ;)
RubeckDK
Explorer
  • July 24, 2026
Hi…
/RubeckDK
You’re very welcome…. dude.. :-)
