suspending job
  • November 1, 2023
  • 110 views
Forum|alt.badge.img+16
aux copy job was suspended at 98 % but when resumed its 70% or some jobs from 45 to 25%
why the job is not resuming where it suspended ?
dude
Forum|alt.badge.img+20
  • Community All Star
  • November 1, 2023
This is likely due additional jobs moved to “To be copied” state in the source copy.
  • November 1, 2023
@dude nope its manually selected jobs automatic selection has been disabled
dude
  • November 1, 2023
Ok, if you right click on the Aux Copu and view jobs, do you see “Partially copied”Jobs?
I wonder if it is just a java glitch where the jobs you selected have not fully completed.
@Ajal
The % is based on application size of the backup jobs selected for process and the amount of data we have processed so far. I would guess when this calculation is done it does not take into consideration if a job that is half way copied or not so the % will jump down, I would expect it to jump back up quite quickly tho.
In my experience i always use the % as a guiding tool but looking at the amount of data processed\to be processed in the GUI and the amount of data on each stream is a better metric to know how much longer the job has to go.
Kind regards
Albert Williams
