t
  • September 28, 2023
  • 61 views
the customer wants to backup some clients through a gateway. We did the configuration of gateway client and network topology.
The main problem is that the customer wants only Commserve to communicate with clients through proxy. Backup was failing because there was no communication to media agent as the customer picked only myCommserve group in the network topology.
So we did share paths from media agent to the Commserve. It was still failing because the client couldn’t reach DDB on media agent. So then we have changed deduplication from ‘On Client’ to ‘on Media Agent’. Now the buckup is running but never ends. It stucked on 25%.
Can we configure backup through a proxy but allow only Commserve to communicate with the client by using share mount paths to Commserve?
If not is there any other way to meet customers requirements?
Lukasz
Best answer by Rajiv
Hello @Lukasz A
If you want to use Commserve as the sole MA for this client under subclient properties > Storage Device > Data Paths,  you can select the commserve as the MA.
After changing the deduplication setting to MA, the backup does not progress, right?  Could you please check clbackup.log on the client and see where exactly its stuck?
Best,
Rajiv Singal
Rajiv
  • October 3, 2023
Hello @Lukasz A
Best,
Rajiv Singal
