Tape Library Zoning with hyperscale x node
  • Jun 20, 2024 6:01 AM UTC
  • 116 views
Forum|alt.badge.img+16
we have added hyperscale x to existing MA zone group but while trying to detect device using hyperscale x MA not able to discover it ,
is there anyway can we check from linux side to see if we can see the drives and tapes like we can do in windows
Hello @Ajal
You could try this command:
Or go over the following and find one more applicable to what you are looking for:
https://www.cyberciti.biz/hardware/unix-linux-basic-tape-management-commands/
Kind regards
Albert Williams
Hello @Ajal
Kind regards
Albert Williams
