Unable to load libCvXSnmp_v3.so library
  • Nov 12, 2024 1:02 PM UTC
  • 63 views
HI
please how to enable smptrapv3 on linux commserve server (RH 8.1)?
im getting error at EvMgrS.log
1285108 13a17f 11/12 13:01:34 ### EvExternal::CvXSnmp_IssueV3Trap() - ERROR: Unable to load libCvXSnmp_v3.so library.
1285108 13a17f 11/12 13:01:34 ### sendExtSnmpTrapAlert() - SNMPV3 alert failed.
any commserve component missing  ?
Thanks Pavel
Best answer by Damian Andre
Hey Pavel, I think you opened a case for this since its the only hit on that error.
Did you check if the file exists? libCvXSnmp_v3.so
If missing a repair on the software may fix it.
  • Nov 16, 2024 12:04 AM UTC
