upgrade CS from 11.20.40 to 11.28.83 directly
  • February 18, 2024
  • 67 views
Forum|alt.badge.img+8
Hello
can I upgrade my Commserve directly from 11.20.40 to 11.28.83 (2022E)?
I have windows 2012R2 on the CS (virtual machine) ,
This is CS and MA together in one VM .
Chris Hollis
  • February 19, 2024
Hi @ariel_b
As Windows 2012 R2 is deprecated in FR28 onwards, I would would recommend doing a Commserve Hardware refresh as per: https://documentation.commvault.com/2023e/expert/commserve_upgrade_with_hardware_refresh_overview.html
The amount of work involved may seem quite extensive but the procedural steps are very good and thorough so should guide you sufficiently.
Let me know if you have any questions.
Chris
