Using Bulk Insert in a dataset for a report.
  • October 8, 2024
  • 52 views
Forum|alt.badge.img+2
I need to create a report that management can use, that compares server data in another database, to server information in Commvault.
Unfortunately, I can’t get access to the other database, and need to run a report against it, and save the results into a tab delimited file.
Using this, I have the SQL set up to bulk insert the data into a temp table, and do what I need to get information from CV, based on that data.  Runs fine.
However, when I try to paste it into a dataset in a report, and “Preview” the data, prior to saving, I’m told that I don’t have permissions to bulk insert.
It appears to be a jdbc error, so I’m assuming they are running java in the background.  I can find what I need to add to a java connection, to allow bulk insert.  However, I have no access to the background java.
Does anyone know of a way to allow bulk insert in a web console report?
  • October 8, 2024
@Billyg03038 - what user are you using to load that data? I suspect you need to grant bulkadmin role to that user in SSMS.
  • October 8, 2024
I’m using bulk insert.  It works in SMSS, as I have the bulkadmin role.  The problem is when I try to use it in a report.  There, I don’t have permssions.  It does show it as a jdbc error, so I’m thinking they are using java in  the background.
  • October 8, 2024
Ah… I believe I found the issue.  Had bulk insert for sqladmin_cv, but not sqlexec_cv...
