Visio Stencils
  • Jul 3, 2023 8:45 PM UTC
  • 5887 views
Hi Community.
Do you know where we can find Visio stencils to create workflow  doc ?
Alessio
Best answer by Rajiv
Hello @Alessio2021
If you have access to Partner Advantage, the Visio stencils can be downloaded from there: Partner Advantage | Technical Enablement | Technical Toolbox
https://partners.commvault.com/PRM_Tools_Toolbox
Otherwise, I have shared it here, you can download directly.
Best,
Rajiv Singal
Rajiv
  • Jul 4, 2023 10:45 AM UTC
Hello @Alessio2021
Best,
Rajiv Singal
  • Jul 4, 2023 12:28 PM UTC
many thanks Rajiv :)
Alessio
Rajiv
  • Jul 4, 2023 12:38 PM UTC
I am glad I was able to assist. Are we good to close this thread @Alessio2021 ?
Best,
Rajiv Singal
  • Jul 4, 2023 1:28 PM UTC
yes you can.
Thanks, again !
