vsa backup sql cluster with shared discs
Hi All,
i have the challange to backup an sql cluster with shared discs.
Error Code: [91:354]
Description: Virtual machine [xyz] is configured with shared virtual disks. Snapshot operations are not supported for shared disks. Use an in-guest agent to protect virtual machines with shared disks.
Source: 1234, Process: JobManager
i tried to filter all scsi discs out wich are shared but the same erro comes during vsa backup test.
is there any possibility to backup the vm only with the systemdrive over vsa backup.
I dint want to go the way over fileagent and in dr case with the onetouch point.
Best answer by Collin Harper
Hello @SSchmidt
Unfortunately backing up VMs with SCSI adapters configured with sharing are not supported and the Filesystem Agent\SQL Agent would need to be used.
VMware - https://documentation.commvault.com/2022e/essential/119379_vmware.html
  • Data You Cannot Back Up
    Virtual machines that contain SCSI adapters that are configured for bus sharing (physical or virtual)
Thank you,
Collin
Hello @SSchmidt
Thank you,
Collin
  • Certified Expert
  • August 30, 2023
Hi Collin,
thanks for the confirmation. Than the only way is the file agent.
Do you know if there are special config needed in the agent like excludes for shared discs ? We only need the Backup for BMR
  • Certified Expert
  • April 7, 2025
hi comeback to this topic :) i have new vms with shared discs for my old vms i added scsi filter in the subclient and it works only vmdks with scsi 0 are backup and can used for bmr now i have new vms with the same config but the backup is not running
