VSA integration with CBT for hypervisor Oracle OCI
  • February 7, 2025
  • 141 views
JT-AV
Novice
Hello Experts,
In recent research I saw that CBT is now available for Oracle OCI, also Metallic is supporting VSA with CBT enabled. Not sure if this capability is available for CommVault Cloud Software, can you help me with this question?
Kind Regards.
JT
Best answer by Sureshkumar S
Hi ​@JT-AV ,
Good day!
From SP40 we support for CBT is enabled when you use linux accessnodes
https://documentation.commvault.com/v11/software/editing_vm_group_settings_for_oracle_cloud_infrastructure.html?
Sureshkumar S
Sureshkumar S
Hi ​@JT-AV ,
Good day!
While searching i could see the Development team is working on the CBT for OCI in CV software and its in testing phase for the software.
It should be available in upcoming release.
Follow the feature release documents and we will be able to see it once released
Sureshkumar S
JT-AV
Novice
  • February 10, 2025
Hi Suresh,
Thanks so much for your reply.
"I found in the 11.38 documentation that it is now supported under Editing VM Group Settings for Oracle Cloud Infrastructure, See the note for more details.
To use changed block tracking (CBT) for backups, move the Use changed block tracking toggle key to the right. When CBT is used, backups only write blocks that have changed since the previous backup. For virtual machines where there is a known issue with CBT, turn off CBT to run backups using the cyclic redundancy check (CRC) method instead.
Kind Regards.
JT
Sureshkumar S
  • February 11, 2026
Hi ​@JT-AV ,
Good day!
Sureshkumar S
