Where DDB+Compress Happens
  • March 11, 2024
  • 37 views
Forum|alt.badge.img+13
Hi Team,
Can we see in the log file whether Deduplication and Compression are performed on the Client or the Media Agent?
We changed Deduplication and Compression to be done in Media Agent via subclient, but we want to see this in the log file as well.
Best answer by Collin Harper
Hello @0ber0n
You can see in SIDBEngine.log. You can filter for “CLSI”. This indicates the DDB lookups are being performed on the Client Side. Otherwise, its occurring on the MediaAgent.
I suspect Compression would be seen in CVD.log on the MediaAgent, though I’ve never had to check “where” compression was being done.
Thank you,
Collin
  • March 11, 2024
Hello @0ber0n
Thank you,
Collin
