Where deduplication and encryption happens
  • Nov 28, 2024 4:29 PM UTC
  • 112 views
Hi Community,
I want to know where deduplication happens in a Global deduplication storage policy?
Client side or Media agent side or both?
if both, then if the encryption is enabled how it dedupes? i know that the encryption happens in a way Compress > Dedupe > Encrypt .
If the encryption enable in agent side, the agent do Compress > Dedupe > Encrypt and send data to media agent. does the media agent decrypts data to dedup again or send the data as it is to Disk lib?
Best answer by Pradeep
Hi ​@sauvegarde
Refer below document on FAQ
https://documentation.commvault.com/2024e/expert/deduplication_faq.html
https://documentation.commvault.com/2024e/expert/optimize_storage_space_using_deduplication.html
https://documentation.commvault.com/2024e/expert/optimize_storage_space_using_deduplication_across_multiple_storage_policies_global_deduplication.html
