Commvault logs max retention, could excessive logging create performance issues?
I was curious if keeping logging of access to the commvault console and file access for security would result in any performance degradation or at what point would this data be trimmed ? if kept indefinitely.
Best answer by Dheeraj Shetty
Hi E51,
Could you please confirm, if you are referring to increasing the Debug level on the Commvault logs or in the Audit Parameters inorder ro capture the events for the Audit Purpose. All user login access details in Java Gui, will be captured in the Audit Trail Report with the below retention set by default for different playback levels. Log in information will be retained for 120 days by default, as it falls under Low Playback level.
Hi E51,
  • October 10, 2024
Hi Dheeraj,
I've been asked if we could increase the audit logs not debugging for several years.
E51
