scrclientID, scrclientID and clientname
  • Mar 16, 2023 3:21 PM UTC
  • 139 views
Hello,I take scrClientID and destclientID from the command:qoperation execscript -sn DataInterfacePairConfig -si listByClient -si clientNameis there any way to associate scrClientID with client name (how to get client name using thise id’s)?thank you very much for helpDorothy
Best answer by Sebastien Merluzzi
@dorota
ok, so you would need to migrate to FR28 to see the new options then.
You can use the SQL Query or REST API for now.
Hi @dorota ,
You can run qoperation execscript -sn DataInterfacePairConfig -si listAll
or you can look at REST API: https://documentation.commvault.com/v11/essential/45898_rest_api_get_client_properties.html
Sebastien
  • Mar 21, 2023 2:22 PM UTC
Hi @Sebastien Merluzzi ,
thank you for hint, but when I run:
“qoperation execscript -sn DataInterfacePairConfig -si listAll “
In output I  have the same scrClientID and destclientID numbers as from command:
“qoperation execscript -sn DataInterfacePairConfig -si listByClient -si clientName“
and I want to find the ClientNames related to this scrClientID and destclientID.
Dorota
@dorota ,
What version are you running please, this is what I have on FR28 or above:
  • Mar 23, 2023 10:19 AM UTC
@Sebastien Merluzzi
version is 11.24.90 and I see it like that (without client Name)
@dorota
