The best way to find PSTs of my workstations and AWS WSs
  • Jan 4, 2024 11:19 PM UTC
  • 29 views
What’s the best way to find all PSTs from all my laptops and AWS Workspaces? I’d try File Analytics to search for .PST from our PCs but unsuccessful due to 500+ objects. The WebConsole was frozen. Had to kill the task. TIA
Hello @dataprotector
Thanks for the great question! As a test if you can perform what you are doing for all your environment but on just a single machine you know has at least 1 .PST file present.
This will show the search you are doing is valid but not scaling in the web console resulting in the crash.
This would most likely be linked to some kind of script timeout and Dev would have to fix it up. I recommend running this test and raising a support case with your findings.
Kind regards
Albert Williams
Kind regards
Albert Williams
