Oracle Table level restore for Multitennant/Container DB's
  • Dec 1, 2023 4:08 PM UTC
  • 44 views
Hi
I noticed in the documentation a note about the lack of Commvault support for Table level restores.
https://documentation.commvault.com/11.24/expert/20248_configuring_oracle_subclients_for_table_level_restores.html
“If you use Oracle 12c or a more recent version, you can only use this procedure for databases that are not Container Databases (CDB). To restore tables in Container Databases, you must use the RMAN command line.”
Are there any plans to support this via the GUI going forwards? Container Databases have been a feature in oracle for over a decade now.
Best answer by Gowri Shankar
With SP23E table level restores with CDB is supported from GUI
https://documentation.commvault.com/2023e/expert/restoring_oracle_table_in_container_database_02.html
Forum|alt.badge.img+16
