Accelerating Backups to HPE StoreOnce Catalyst Storage Library
  • December 12, 2024
  • 107 views
Hello Community,
Based on CM's documentation, you can accelerate backups by installing the Storage Accelerator software on clients.
https://documentation.commvault.com/11.20/accelerating_backups_to_hpe_storeonce_catalyst_storage_library.html
Question: Is this functionality supported when the StoreOnce appliance is connected with Commvault via Fiber Channel?
Thank you
Best answer by Damian Andre
Hi ​@Georgios
No this is not compatible with your setup. What storage accelerator does is allow clients themselves to directly write to storage media without going through an intermediate Media Agent. It is more used for cloud libraries or NAS devices using file shares as storage targets - these can all be accessed directly without having to go through a dedicated Media Agent first. In your case, only your media agent has access to the catalyst via FC.
Hi ​@Georgios
  • December 15, 2024
Hi Damian,
What If I change the connection of media agent from FC to IP? It will work?
Thank you
