add exception on scheduler
  • Dec 4, 2023 4:40 AM UTC
  • 107 views
click by mistake 😥
Can I rollback schedule [Add exception]?
Best answer by Chris Hollis
@chris_ahn
Hi Chris,
Right click the Commserve > view > schedules > edit the schedule in question >
Whatever you added should appear there:
Hope this helps.
Regards,​​​​​​​
Chris
Chris Hollis
  • Dec 14, 2023 4:28 AM UTC
@chris_ahn
Hi Chris,
Hope this helps.
Regards,​​​​​​​
Chris
