Auxcopy completed with error
  • Oct 11, 2023 5:54 AM UTC
  • 78 views
Dear Team & Mike Struening,
We are facing auxcopy completed with error issue last few months, We dont have Tape backup. We are facing below error:-
Please help us to resolve the issue.
Best answer by Pratik
Hi @Vaibhav Waghmare ,
I checked he details.
From the error, we see the Chunk processing is failed. I suggest to check the following options:
1. On the Particular disk and mount path, check if you are available to acces the chunk on its folder [V_xxxxxxx].
2. Check if the Read/write permissions are given to the folder/path
3. Check if the chunk is in readable format and having all files on it.
4. As the error message mentioned the job ID, go to that Client/Job and run a verification job to check if the particular job is healthy or not.
5. If the Verification job fails, there are chances that the job is corrupted due to bad chunk/file.
Further if the issue persists, please reach out to Commvault team for a detailed review on the issue.
Also, please refer the available solutions on Commvault Docs with similar issues:
https://documentation.commvault.com/search?q=error%20while%20processing%20the%20chunk&oem=commvault&majorVersion=11&minorVersion=32&site=essential#q=error%20while%20processing%20the%20chunk&t=All&sort=relevancy
Forum|alt.badge.img+8
  • Oct 11, 2023 12:25 PM UTC
