Auxcopy Live sync replication
  • Jul 29, 2024 3:55 PM UTC
  • 993 views
We are getting below error, during live sync Could you please help to fix this issue.
Error Code: [13:245] Description: [Deduplication failure] [Dedupe disk media] [Encountered a network error. Could not connect to the CVD on the target MediaAgent to launch the DDB engine. MediaAgent: nwccewprdma01. DDB: Azure DR Blob_292. DDB Id: 292. Partition Id: 301. . (Run check readiness on the client to ensure client is able to connect to all required backup infrastructure.)] [in media (CV_MAGNETIC) , Path (C:\BackupMountPoints\22CMA01_MP01\174RFD_10.30.2023_16.47\CV_MAGNETIC\V_1491701)] Source: pgms22cma01, Process: CVJobReplicatorODS
Log :
26064 41bc  07/29 10:27:07 6051301 [DM_BASE    ] ConWrtrDDB [7708]: Connecting using engine id [292]
26064 41bc  07/29 10:27:07 6051301 SubstoRoutngInfo() - SubstoRoutngInfo: EngId[292] 0-301-0 => 0-301-0 Clnt=[nwccewprdma01] Path=[D:\DDB] Status=[0]
26064 41bc  07/29 10:27:07 6051301 Connect: Connecting to Engine [292], Group [0], Client [nwccewprdma01], Host [nwccewprdma01*nwccewprdma01*8400], Recovery Mode [false]
26064 41bc  07/29 10:27:09 6051301 ERROR: CvFwClient::connect(): Connection failed on pgms22cma01 with these errors: 1) No direct tunnel to nwccewprdma01; 2) Couldn't bring up any automatic tunnels to nwccewprdma01*nwccewprdma01*8400
26064 41bc  07/29 10:27:09 6051301 LaunchGroupRemotePart1: Cannot connect to CVD on host [nwccewprdma01*nwccewprdma01*8400]. Error [0xE8090010:{CCvNetwork::Attach_RemoteDLL(1526)} + {CCvNetwork::Attach_RemotePort(1400)} + {CCvNetwork::GetConnection(3273)} + {CSessionConnectionSocket::GetConnection(220)/EventMessage.0x09000010.9:16.(Remote machine [nwccewprdma01]. The socket connect failed. Error returned [-1=Connection failed on pgms22cma01 with these errors: 1) No direct tunnel to nwccewprdma01; 2) Couldn't bring up any automatic tunnels to nwccewprdma01*nwccewprdma01*8400]. Check Network Connectivity.)}]
26064 41bc  07/29 10:27:09 6051301 Connect: Unable to send message to [nwccewprdma01][nwccewprdma01*nwccewprdma01*8400] to launch engine [292] for group [0]. Error [Could not connect to the CVD on the target MediaAgent to launch the DDB engine. MediaAgent: nwccewprdma01, DDB: Azure DR Blob_292, StoreId: 292, SubStoreId: 301]
26064 41bc  07/29 10:27:09 6051301 [DM_BASE    ] ConWrtrDDB [7711]: Cannot connect to the DDB. Error [Could not connect to the CVD on the target MediaAgent to launch the DDB engine. MediaAgent: nwccewprdma01, DDB: Azure DR Blob_292, StoreId: 292, SubStoreId: 301]
26064 41bc  07/29 10:27:09 6051301 [DM_BASE    ] Error handler: Setting JPR for [errorType - 3] [Error-code - 53002] [Error-module - 218104058] [Event-ID - 536871511] [Handler type - 218104062]
26064 41bc  07/29 10:27:09 6051301 [DM_BASE    ] setting job pending reason [job-ID - 6051301] [job type - 2] [Argument count - 4]
Best answer by Swati Himmatramka
Hello SSP,
→ As per the log cuts, we could see connection issue between pgms22cma01 and nwccewprdma01 over CVD port 8400 and due to which it is not able to spawn the DDB engine.
26064 41bc  07/29 10:27:09 6051301 Connect: Unable to send message to [nwccewprdma01][nwccewprdma01*nwccewprdma01*8400] to launch engine [292] for group [0]. Error [Could not connect to the CVD on the target MediaAgent to launch the DDB engine.]
→ Make sure the connection between the required servers “pgms22cma01 and nwccewprdma01” is fine over the CV ports i.e 8400
Hello SSP,
