“Client Direct to Device” problem with PowerProtectDD integration
  • Aug 22, 2023 3:27 AM UTC
  • 199 views
After configuring Data Domain Boost Access library,there is still ethernet traffic through MA when backup.
So what can I do to achieve this feature (The Commvault Data Domain Boost Access library type also offers “client direct to device” accelerated backups and restores. Clients can backup and restore directly to and from the Dell EMC® Data Domain® without having to send the data through a remote MediaAgent eliminating additional network transmission).
CV:11.32
DDVE:7.9
Best answer by Gianluca E
Hello
after following the instructions given by Rajiv you have to check if MA is already installed on the client side. Starting the backup you can check on DD side (if you have access) the client connection via DDboost with the following command
ddboost show connection
to check if the client have a connection to DD (you can check the name and DDboost module version)
ddboost client show active all
to check in real time the client open channel for backup.
Gianluca
Rajiv
  • Aug 22, 2023 1:07 PM UTC
Hello @lizf
Its a 2 step process, please confirm if you have followed both the steps:
https://documentation.commvault.com/2023e/expert/158333_configuration_for_data_domain_boost_storage.html
Moreover the MA has to communicate with commserve server for other tasks as well like index updating, deduplication, ageing etc. Moreover if its an access node then snapshots will be using it too.
If you are still facing performance issues, you can raise a case with us so that we can analyze the configuration and the environment accordingly.
Best,
Rajiv Singal
Forum|alt.badge.img+2
  • Mar 5, 2025 9:58 PM UTC
Hello
Gianluca
