CMK change on S3 bucket
currently I backup S3 bucket with managed key, plan change the key to CMK, will commvault support S3 bucket backup with CMK?
Best answer by Scott H
Hi Xiwen,
Thanks for your question.
CMK is supported, to find out more please check the doc link below:
https://documentation.commvault.com/2023e/expert/requirements_and_usage_for_aws_iam_policies_and_permissions.html
Kind regards,
Scott Henderson
Media Management - Technical Team Lead (APAC)
Scott H
  • January 12, 2024
Hi Xiwen,
Kind regards,
Scott Henderson
  • January 12, 2024
Scott,
Thanks for your guide. Will you link cover cloud apps S3 backup?
current I backup S3 bucket by cloud Apps, not mentioned support CMK or not support the feature on below link.
https://documentation.commvault.com/2023e/expert/amazon_s3_overview.html
