Commvault doesn't remove snapshots after MongfoDB backup.
  • Nov 8, 2024 8:43 AM UTC
  • 118 views
Forum|alt.badge.img+9
Hello All,
we have Mongo Sharded Configuration backup on COmmvault. We backup it daily full. As you know COmmvault take snapshot before backup and , It deletes snapshots after backup copy. When I check the client on Commvault there is not any snphot presented. But There are many snapshot taken by COmmvault on host. İs it fine if we delete them manuelly or how can we delete them? Commvault should delete them automaticly right?
Snapshots on host:
 [gbmnsp08]~#lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
cvnv_1213025853 datavg swi-I-s--- 50.00g lv_data01 100.00
cvnv_1615395985 datavg swi-I-s--- 50.00g lv_data01 100.00
cvnv_2032137259 datavg swi-I-s--- 50.00g lv_data01 100.00
cvnv_2251453908 datavg swi-I-s--- 50.00g lv_data01 100.00
cvnv_2532432752 datavg swi-I-s--- 50.00g lv_data01 100.00
cvnv_3191856748 datavg swi-I-s--- 50.00g lv_data01 100.00
Best answer by Damian Andre
Hmm I dont think so. I think clean up what is left over and see if it continues to happen. If so the logs might be able to tell why the snapshot is not attempting to be removed or why it is failing to be removed.
They should be automatically deleted - would have to dive into the logs to see why they are not. If there are no jobs associated with the snap primary of this client then they should be OK to delete using something like dmsetup remove
Might be worth cleaning them up and then checking again. Also ensure this is configured correctly:
For LVM snapshots, an inline backup copy is triggered after the snap backup is complete. The snapshot retention for LVM snapshot copy must be set to 0 days in the server plan associated with the MongoDB cluster.
It could be that the retention has been set higher and therefore the snapshots are retained
  • Nov 9, 2024 5:29 AM UTC
Hello @Damian Andre
The snapshot retention for LVM snapshot copy has already  be set to 0 days. WHen I check snapshot on COmmvault I dont see any snapshot.
Sometimes we deleted it from commvault with the force erase snapshot command.  could it have affected it?
  • Nov 9, 2024 9:36 PM UTC
