CSDB restore from media explorer on HPE catalyst
  • September 17, 2024
  • 74 views
CSDB restore from media explorer on HPE catalyst?
We are using hpe catalyst library and DR storage policy is configured to write to HPE catalyst.
If in case of disaster how do we recover most recent backup using media explorer.
https://documentation.commvault.com/2023e/expert/retrieval_of_disaster_recovery_dr_backups_from_storage.html
I dont see such option in BoL.Please advise.
Even though command center shows the HPE storonce as cloud we cannot run cloudtesttest on this storage I believe,
Best answer by Wasim
Hi @AbdulIkram,
Restoring the CommServe Database (CSDB) from HPE Catalyst using Media Explorer is not directly supported. Media Explorer is typically used for tape or disk storage.
Wasim
  • September 19, 2024
Hi @AbdulIkram,
Wasim
  • September 21, 2024
Hi Wasim, I hope you are doing well. Thank you for taking a look at this post.My question is not yet answered.
As an alternate solution  ,we dont have Network path(due to some security reasons not possible) and cloud storage to upload phase1 of CSDB job.
So we want way to restore the CSDB from HPE catalyst in case of disaster,
My question is still open,Can you please check with Dev team what is solution here?
