CV11.28 AWS Combined Storage Tier Recall questions
  • Feb 15, 2024 10:13 AM UTC
  • 68 views
Patrick Dijkgraaf
Certified Expert
Forum|alt.badge.img+8
Hi all,
At a customer, we are using Combined Storage Tiers:
  • CV 11.28
  • AWS Deep Glacier / Standard-Infrequent Access
We have a few questions on this:
  • When we do a restore, the Recall workflow kicks in. We see that it initiates the Recall and then waits for 13 hours before checking the Recall Success. Why is it only checking after 13 hours? The data might be available sooner, so it would make sense checking earlier.
  • Which Recall type is used by default (with CV 11.28), is it Standard or Bulk?
Thanks in advance!
Best answer by Damian Andre
hi @Patrick Dijkgraaf,
The recall mode uses standard by default. If you manually execute it you can override it to bulk or expedited if supported on your storage class:
Retrieval option: The recall mode that must be used to recall data. Default is set to 0, which is Standard mode. Valid values are:
0 - Standard
1 - Expedited
2 - Bulk
The workflow does not seem to be looping or waiting at “Checking Recall Success” - this activity checks if the recall was successful from the output of the previous activity, e.g the previous activity’s output is piped into this activity. So there is no wait or inherent delay that I can see - this is actually how long it took in this instance.
  • Feb 16, 2024 2:12 AM UTC
0 - Standard
1 - Expedited
2 - Bulk
