Data Integrity validation failed for the data read from media. error
  • Dec 4, 2023 10:37 AM UTC
  • 631 views
Hello ,
I have one problem when making auxillary copy to Tape.
I have done the data verification and problem still persists.
Any help would be good.
BR
Tomislav
Hello @tstaba
The following goes over a report you can run to show the Data integrity validation status in a report:
https://documentation.commvault.com/2023e/expert/8915_data_integrity_validation_reports.html
This might provide some InSite as to what is going on and what may be causing you to fail.
When we are talking about data’s recoverability i would always recommend raising a case to support to review as if there is some level of corruption after write then we want to get on top of it ASAP.
Please advise if this helps at all.
Kind regards
Albert Williams
Hello @tstaba
Kind regards
Albert Williams
