DDB lookup very high percentage (98%) of backup load with 68% deduplication savings
  • Dec 22, 2024 9:11 PM UTC
  • 407 views
 Here is a screenshot of the current status of the ddb.   Backups are running over desired time windows with 98.27% of load being ddb lookups.   We are close to capacity currently with backup storage though this will be resolved soon.   How can we resolve the high DDB lookup % issue?
DDB and job status screenshots below.
Make sure your DDB is hosted on a SSD, preferably one that is NVMe connected, and if this is already the case then you should look into the specs and health state of the drive.
  • Dec 23, 2024 3:43 AM UTC
Hi ​@Paul D NZ,
Here the issue is with the Q&I value. The average Q&I time is the average time (in micro seconds) that was taken for insertion and query of signature in the deduplication database.
https://documentation.commvault.com/2024e/expert/monitoring_deduplication_database_partitions.html
  • As per the screenshot, the backend size of store ID:17 is 70.52 TB
  • Also, the "Garbage collection" has been enabled.
  • I hope the respective MA is associated only with the store ID:17
  • 1 Node, 1 SSD disk per node will support up to 75 TB. This will be under "Medium" range.
https://documentation.commvault.com/v11/expert/hardware_specifications_for_deduplication_mode.html
  • For this workload we require "600 GB SSD Class Disk 1,2 2 GB Controller Cache Memory7 For Linux, the DDB volume must be configured by using the Logical Volume Management (LVM) package" disk.
  • 5K dedicated Random IOPS
https://documentation.commvault.com/2024e/expert/testing_iops_of_deduplication_database_disk_on_windows.html
  • Please let us know whether the DDB disk is hosted from a local SSD disk.
  • Is it configured from a dedicated RAID or shared with any other resource. Also, share the IOPS details.
Please refer to the below document, to run the IOmeter test to validate the IOPS.
Wasim
Onno van den Berg
Forum|alt.badge.img+24
