DDB verification schedule and Quick verification
Hi CV Experts,
We are on 11.32.59.As per default schedule DDBVerf configured in our environment. It is selected as Quick verification.But in 11.32 documentation, it is mentioned default schedule to run with “verification of existing jobs on disk”.
https://documentation.commvault.com/2023e/expert/verification_of_deduplicated_data.html
Kindly note,we have 1PB of data, so running ‘verification of existing jobs on disk’ shows estimated time to complete as more than one month.Can we run default schedule with Quick verification.Does it identify the corruption or missing in chunks on storage ?
https://documentation.commvault.com/2023e/expert/data_verification_of_deduplicated_data.html
Best answer by Damian Andre
Quick verify is not exhaustive - it looks for the existence of files but does not read the data. Since the data is not read it cannot accuracy locate any data corruption. If you suspect some sort of data corruption or are getting error in your auxiliary copy, then I’d highly recommend “ verification of existing jobs on disk “ instead. If you are not getting auxcopy errors and there is no indication of possible data issues, quick verify should be ok.
  • November 9, 2024
Thank you. That helps
