delete old backups
  • December 5, 2023
  • 13 replies
  • 4308 views
i have the commvault  v11.28.83. i want delete old backup from disk manually because of i have not empy space on my storage disk. the agging option is finishing works, but the disk space is not emptied.how to do it?
Best answer by MarkusBaumhardt
In a regular Storage Policy Copy (i.e. not WORM enabled) and with full management permissions on the jobs, the context menu should have an option “Delete Job” at the bottom of the menu:
No idea why this is not shown in your case. Are you sure
  • you are in the Job View of the Storage Policy Copy (not on the Client)?
  • The Storage Policy Copy is not WORM enabled?
  • you have full management rights on the Storage Policy and on the Jobs?
Hi @gogi100 ,
You can check
Sebastien
  • December 5, 2023
i dont need ‘Delete a Job From a Copy’ then deleting data from backup, to free up disk space for new backups
Can you check the Disk Library and View Contents what is taking the space?
Can you also check dataaging.log on Commserve?
  • December 5, 2023
also on location on storage, there is folder @Recycle, like on picture, that which occupies a space of 25 GB. can i delete data from this folder?
  • December 5, 2023
i checked disk library >view contents and i found
but i dnot know how delete those biggest backup.
You can open the Recycle Bin and see what is inside. Then empty it if you do not need the deleted data.
Now I am confused, I sent you the link to delete the jobs you don’t want to keep, but you said “i dont need ‘Delete a Job From a Copy”.
  • December 5, 2023
I want to free up disk space for new backups. whether that space is also occupied by jobs, if the answer is yes, then they should be deleted as well
  • December 5, 2023
what is @ Recycle Bin?
Hi Gogi100,
I think we need to clarify the understanding here as in Commvault Jobs represent backup data on the disk library. You can only delete entire Jobs which means that all data that was backed up with a specific Job is deleted.
So, if you want to free up space on the disk library, then you need to delete Jobs.
You can do that using the CommCell Console for example in that you navigate to the Storage Policy Copy, right-click on it and select “View Jobs”. In the Job View, you can then right-click individual Jobs and mark them for deletion. After that you need to start Data Aging which will care about the selected jobs being removed from the Commvault database and physically deleted from the disk via a separete pruning process that is running in the background after the Data Aging was run.
I hope this clarifies the process.
  • December 5, 2023
Hi Gogi100,
but when i right click on individual job, there is not option for deleting. the picture
Forum|alt.badge.img+8
@gogi100 you can also check if this KB helps
https://kb.commvault.com/article/80543
Can we delete the old backup jobs from command center web console because we are using 11.36.49 version and doesn’t able to use commcell console with this version?
