Delete Storage Policy from Command Center
  • Aug 28, 2024 11:00 AM UTC
  • 88 views
new install here, needed to make a change on a Cloud Storage (HPE StoreOnce), and needed to recreate the catalyst store.
I’ve deleted everything, but now from command center (11.34) I says when recreating the CLOUD Storage is already created.
the commvault documentation only refers to commcell operation, but this is strange because commcell is not available on 11.34
https://documentation.commvault.com/2024/expert/deleting_backup_or_archive_storage_policy.html
ERRO:
Failed to create the Storage Policy [NAME_OF_STORAGE_POLICY]. A Storage Policy with the same name already exists
any help will be much appreciated
regards
Best answer by pma
hi, figured out my self
anyways heres the resolution
using command line:
qlogin (used to login to commvault command line interface)
qlist sp (lists the storage policy)
then download the xml template from:
https://documentation.commvault.com/11.16/deleting_storage_policy_copy_02.html
and execute the following:
qoperation execute -af c:\temp\Delete_SP_copy.xml -storagePolicyName NAME_OF_THE LISTED_STORAGE_POLICY
done!
  • Aug 28, 2024 11:51 AM UTC
using command line:
done!
