Disable WORM storage lock feature
  • December 17, 2024
  • 809 views
We have doubt about Disable WORM storage lock feature.
Currently we are on 11.32.59 and storage is Netapp GRID and HPE Catalyst.We are planning to enable the Storage lock feature.
If in case we have to disable the WORM storage lock once enabled, we have to follow the below steps.
https://support.commvault.com/Article/Details/82504
In our environment we dont have SMTP configured.What is the workaround here? Please advise.
Forum|alt.badge.img+24
  • December 17, 2024
You can use a tool like papercut to have a simple local email server set up temporarily. Honestly this is what I would do if you dont have SMTP available:
https://github.com/ChangemakerStudios/Papercut-SMTP
Erase4ndReuseMedia
Forum|alt.badge.img+16
Given that disabling Compliance Lock can be approved / denied via the CommCell Console and Command Center is it really necessary to have SMTP available.
  • December 18, 2024
​@Damian TThank you. I will give a try on Test setup and let you know if the approve/deny works.
