Duplicate Barcode Tapes
  • Mar 21, 2025 6:22 PM UTC
  • 154 views
yamric
Novice
I have tapes coming back from Fe.Mtn which have duplicate barcodes. one tape is from our old Networker environment and the other from Commvault. Is there a way to use the “cv tape tool” to see the content on the tapes before I start the restore operation?
Best answer by Jon Vengust
Hi Richard,
Hope you’re doing well.
Correct. You could use the CV Tape Tool to read the On Media Label (OML) and confirm whether the tape was written against by Commvault (most likely referred to as Galaxy) under the Application parameter/value.
Jon Vengust
  • Apr 8, 2025 5:52 AM UTC
Hi Richard,
