Effect of Changing the Default UNC Path on DDB Indexing.
  • Nov 21, 2024 7:35 AM UTC
  • 33 views
I experienced slow incremental/synthetic backups due to limited throughput. I would like to understand if changing the default UNC path and indexing on the DDB will affect the backup process.
Best answer by kkarthikk
Hi ​@Nabin
Could you please have more information about changing the default UNC path?
We need to review the logs to find out where the slowness. I would request you open a support case so that we can go through the log files
Karthik
  • Nov 25, 2024 2:17 AM UTC
Hi ​@Nabin
Karthik
