Enable 0 cycle retention on WORM pool
  • May 20, 2026
  • 30 views
Hello community,
we used a deduplicated WORM cloud storage pool  for a while but needed to start fresh because of unexpected growth.
In the process of aging the data of the old pool we noticed an issue because of the default 1 cycle retention which required a workaround to bypass the cycle retention.
Therefore we would like to enable zero cycle retention on the new WORM pool like described here: Configuring WORM Storage Lock
When preparing the pool and assigning the first storage policy to it I noticed that the cycle retention got increased to 1 after enabling WORM despite running the command from the documentation beforehand.
So my question is: Is there more to do than described in the documentation to enable the zero cycle retention on WORM pools or is the GUI just “showing” 1 cycle but using 0 in the background?
Best answer by Marcel_RE
I tried reproducing the issue again, but now it seems like the setting was applied correctly.
The only difference as far as I can tell was that I did not have a plan already assigned to the pool before enabling WORM.
When executing the command on an empty pool with no assigned plan copies the cycle retention stays 0 on the pool and on the plan copies added afterwards.
So maybe this should be added to the documentation if my assumption is true.
  • May 22, 2026
Hi ​@Marcel_RE ,
To enable zero cycle retention, you must set the number of cycles to 0 in the storage pool retention settings and the value must be set and saved.
  • May 22, 2026
Hi ​@Pradeep,
we used this command in our testing and it seemingly succeeded but I was wondering if it is expected behaviour that the cycles will get increased to 1 again after enabling WORM?
Does the zero cycle retention still apply then?#
Thanks in advance!
  • May 22, 2026
