Error adding nutanix cloud storage
  • Jun 26, 2024 8:03 PM UTC
  • 108 views
Hello Gentlemen, I would like help with the following error.
A new Bucket was created in our Nutanix, with the WORM immutability function. And in commvault, when trying to create a new cloud storage, it presents the following error in the image below:
Note: I performed the test using the Cloud Test Tool software and the error returned talks "You must provide a Content-MD5 header with object blocking fields" .......Image below:
Test Upload/Donwaload :
Test Access Functionality Check:
I am sending the Logs as an Attachment:
CVD (taken from commserve)
EvMgrs (taken from Mediaagent)
CloudActive (taken from Mediaagent)
Best answer by Leandro Barbieri
Hello my friend! Thank you very much for your help, it worked here.
NOTE: I had already checked this same tip in this thread from 2 years ago
https://community.commvault.com/storage-and-deduplication-49/aws-object-lock-issue-3170e )
and they had mentioned that it would be I fixed the problem in the update, but I'm already on the current version 11.32.54 and there's no solution. Fortunately, the software itself allows us to make additional settings.
Hugs here from Brazil. Thanks again!
Rajiv
  • Jul 1, 2024 8:10 AM UTC
Hello @Leandro Barbieri
Could you please add the below additional key on the MA and then check the configuration?
Value: nCloudForceMD5
Category: MediaAgent
Type: INTEGER
Value: 1
Best,
Rajiv Singal
