Error Code [12:138]
  • Sep 5, 2024 4:46 PM UTC
  • 52 views
Hi Guys,
I know this type of error has already a solution, which is either to suspend and resume the job or to run a verification job data, but both have not worked. Does anybody else have any suggestions ?
Error message :
Error Code [12:138]
Description : Error occurred while processing chunk [XXX] in media [XXX], at the time of error in library [XXX] and mount path [[XXX] E:\MAGLIB\SATA15], for storage policy [XXX] copy [XXX] MediaAgent [XXX]: Backup Job [XXX]. The parameter used for the current operation is not supported by the Operating ssytem, OD Drivers or the underlying Hardware. Source: [XXX], Process: [XXX] .
Best answer by Wasim
Hi @Sebastian.Ghahremani ,
We need to review the logs from MA.
It seems you already raised a case with the support yesterday. The Engineer requested to upload the log of MA.
Please share the logs with the Engineer to investigate further on this issue.
Wasim
  • Sep 6, 2024 6:32 AM UTC
Wasim
