File Archiving on Isilon - Stubbing did not happen
  • Nov 21, 2024 8:21 AM UTC
  • 85 views
Hi, we are testing the file archiving on an isilon and the archiving itself works fine but it does not create any stubs.
Error code: [72:106]
Description: Warning: Job completed partially successful: Stubbing did not happen
We tested the same on a Netapp share where archiving and stubbing works fine.
Does anyone have had any similar issues?
Best answer by Sureshkumar S
Hi ​@andcla767 ,
Good day!
We need to look into the logs to find the reason for this behavior (GXHSMSTUB.log and filescan.log)
Raise a support case to check this further
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
Hi ​@andcla767 ,
Good day!
Sureshkumar S
