First full backup copy is partially copied to secondary copy
  • Feb 29, 2024 5:02 AM UTC
  • 53 views
First full backup copy is partially copied to secondary copy, DASH is enabled, tried to recopy those jobs but steams will pick up the job id’s after sometime we see the network errors. Please provide solution to fix it.
Note : Auxiliary copy is running over internet link.
Best answer by SMD
Hi Manjunatha Reddy,
We will have to analyse the logs to understand what exactly is happening as usually error’s seen on the job are general. Would request to raise a support incident for the analusis.
Suleman
  • Feb 29, 2024 5:11 AM UTC
Suleman
Hi @SMD  I opened a case 240226-34 and attached the logs to the case. Please go through it.
