Health Report errors
Forum|alt.badge.img+2
Where can i find the health report that tells me the heath of the my platform. Not just the critiical, good, or info example page . I am looking for where on the  command center it tells me what’s not up to date or is all set. I did  find it under the health page. Thanks in advance.
Best answer by RajA
Hi @DBA
You can go to Health report from ‘Reports’ in command center. Click on ‘Software Version’ section to view the update status of machines in your commcell.
  • July 30, 2024
Hi @DBA
  • July 30, 2024
Thank you for you help, i greatly appreciate it. Your pics were helpful. It was security assessment that i was looking for. Found what i needed. Again thanks for the help
