I'm trying to find a way to display the configuration of a copy that is part of a Storage Policy.
Did anyone find a way to do this yet?
Br,
Fred
Br,
Fred
Best answer by kkarthikk
Hi
You should be able to view the copy configuration buy right clicking on the copy->properties and you will be seeing the configuration(if it is selective copy, what are the fulls selected can bee seen from selective copy tab).
You can refer the below documents for reference.
https://documentation.commvault.com/2022e/expert/copy_properties_selective_copy.html
https://documentation.commvault.com/2022e/expert/copy_properties_copy_policy.html
Karthik
