How to display a copy configuration from a storage policy
  • Nov 19, 2024 3:39 PM UTC
  • 92 views
I'm trying to find a way to display the configuration of a copy that is part of a Storage Policy.
Did anyone find a way to do this yet?
Br,
Fred
Best answer by kkarthikk
Hi ​@Fred,
You should be able to view the copy configuration buy right clicking on the copy->properties and you will be seeing the configuration(if it is selective copy, what are the fulls selected can bee seen from selective copy tab).
You can refer the below documents for reference.
https://documentation.commvault.com/2022e/expert/copy_properties_selective_copy.html
https://documentation.commvault.com/2022e/expert/copy_properties_copy_policy.html
Karthik
  • Nov 20, 2024 5:24 AM UTC
Hi ​@Fred,
May i have more details on what configuration you are look from the storage policy copy level?
Karthik
  • Nov 20, 2024 9:02 AM UTC
Hello Karthik,
When you create a Copy (e.g. Aux Copy) into Storage Policy there is a view where you define the selection (all or selective copy, etc.). When the copy is finally created, it is impossible to view the configuration. Then in context you are not the creator, it is impossible to know what has be done.
So, how to view the configuration of a copy (e.g. Aux Copy).into Storage Policy ?
Br,
Fred
  • Nov 21, 2024 12:01 AM UTC
Hi ​@Fred,
Karthik
  • Nov 21, 2024 8:49 AM UTC
Hello Karthik,
I did not pay attention, i did focus on configuration grey out.
Br,
Fred
