How to find out tape library WWPN details?
  • Jul 31, 2024 7:20 PM UTC
  • 26 views
I need to  find out tape library WWPN details, can some one help quciky??
Best answer by SMD
Hi @Ravi kommiri ,
There is no commvault tool which help you with this, please engage your hardware vendor. You can use Tape vendor GUI for the details.
Suleman
  • Aug 1, 2024 2:17 PM UTC
Hi @Ravi kommiri ,
Suleman
