Can someone help me how to get Commvault CCID
Best answer by SMD
View originalCan someone help me how to get Commvault CCID
Best answer by SMD
View originalHi
There are multiple ways to get CCID, once of the easiet way is to launch Commcell console and look at the bottom of the screen
or Login to Command Center
Suleman
Hi Suleman, thank you so much for your help. i was little confusing between Commcell ID and CCID.
Now i understand both are same. Appreciate your time and help.
Hi
Glad to help :)
Suleman
