How to get my Commvault CCID, what is CCID?
  • Apr 3, 2024 7:11 AM UTC
  • 1273 views
Can someone help me how to get Commvault CCID
Best answer by SMD
Hi @Kumar Devaraj ,
There are multiple ways to get CCID, once of the easiet way is to launch Commcell console and look at the bottom of the screen
or Login to Command Center
Suleman
  • Apr 3, 2024 7:33 AM UTC
Hi @Kumar Devaraj ,
Suleman
  • Apr 3, 2024 8:17 AM UTC
Hi Suleman, thank you so much for your help. i was little confusing between Commcell ID and CCID.
Now i understand both are same. Appreciate your time and help.
  • Apr 3, 2024 9:51 AM UTC
Hi @Kumar Devaraj ,
Glad to help :)
Suleman
