Indexcache -Low disk space issue
  • Dec 7, 2023 7:47 AM UTC
  • 321 views
Hi Team,
Greetings!!!
In our Commvault infra , We are getting below error
“The Disk used to store the index on the analytics engine is running at 80 percent of capacity, Please add more disk space to prevent failures during analytics operations”
File\ C:\Program files\Commvault\ContentStore\IndexCache\AnalyticsIndex
We have already change the existing Index file path to other Drive Like E:\, But still we are getting the mentioned above error daily,
Could you please suggest any solution for this issue
Best answer by Sebastien Merluzzi
Hi @Adarsh.op ,
It is possible that we need to run a script to update the CS DB table.
Can you log a case with Support so we can review and confirm.
Sebastien
Hi @Adarsh.op ,
Sebastien
