Infinidat with Intellisnap
  • Jul 15, 2024 1:09 PM UTC
  • 68 views
Can anyone advise on how to integrate Infinidat with Commvault Intellisnap. Can we Use Commvault aux copies to copy the app-consistent primary snapshots to another storage array Or Commvault storage.
Will these remote copy snapshots will be revert capable ?
Best answer by RajA
Hi @Kay5
The INFINIDAT Replication feature does not support the revert operation from the snapshot copy or from the replica copy.
You can check the documentation here to know more on how Inline Replication and Active-Active replication of Infinidat works and how-to configure.
https://documentation.commvault.com/2024e/expert/infinidat.html
  • Jul 16, 2024 12:38 AM UTC
Hi @Kay5
