Intellisnap with NetApp - Prefix / Suffix for Snapshot Naming
  • July 24, 2025
  • 50 views
Hey,
we are using Intellisnap Snapshots with NetApp
Question is, is there a possibility to modify the snapshot Name with a prefix or suffix like “daily” “weekly” or something else?
I only found the general Naming convention:
https://documentation.commvault.com/2024e/essential/naming_conventions_for_snapshots_created_by_netapp_array.html
No other options.
Thx & BR
Marcel
Best answer by Jace Ross
Hi Marcel,
Unfortunately there is no way to change prefix/suffix of a Commvault created intellisnap snapshot for NetApp. If this is a feature you would like implemented you can raise it with your account manager who can create a modification request if possible.
Forum|alt.badge.img+9
  • July 25, 2025
Hi Marcel,
