Is there any way to make storage pool with more than 6 DDB Partitions?
  • September 16, 2025
  • 94 views
Hello guys!
we have 5 XL Linux Media agents, and all of them have 2 DDB Partitions in the size of 5.9 TB. both of the DDB partitions are configured in RAID 1
when trying to configure storage pool from these media agents, we only can configure up to 6 DDB Partitons, and we need all 10 partitions to be available within the storage pool
is there any chance of it?
Best answer by Wasim
Hi ​@Omer Kanias ,
The default value for “Maximum allowed substore configuration” is 4, and it can be increased up to 6.
https://documentation.commvault.com/2024e/commcell-console/media_management_configuration_deduplication.html
If there is a requirement to increase this limit further, please raise a Commvault Support case to validate feasibility.
Wasim
  • September 17, 2025
HI ​@Omer Kanias,
No, it is not possible to create a storage pool with 10 DDB (Deduplication Database) partitions.
The maximum number of partitions that can be configured in a deduplication database is controlled by the Maximum Allowed Substore Configuration parameter. By default, this value is set to 4, and the supported range is 1 to 6 partitions per DDB. Therefore, configuring 10 partitions is not supported.
Rohit Ravi
Hi ​@Omer Kanias ,
Wasim
